Remote control air filter
powertools":3rhohnmu said:
My simple question was is it not better to have an air flow in a downward direction rather than upwards.
Hello,
It makes little difference. The filter is NOT filtering the dust that comes off the machine, the primary sources of extraction are for that, and dust masks. The filter keeps the air in the room cleaner. Once the machine is turned off, the extractor cut out and the dust mask removed the air in the shop is cleaner to breathe, as the air filter should circulate the room air volume at least once every 10 minutes. They are even left on for a couple of hours after the occupant has gone home, to mop up all the floaty fine dust, so the air (and horizontal surfaces) is clean the next day.
Mike.
Dry wood dust is lighter than air and will float high in the workshop for extreme lengths of time on the slightest of air currents that you may not even notice. Hardwood dust is lighter than softwood and will cause more problems with long term health.
The air filters are just hopefully catching a good deal of these particles - but it would be best if I stopped brushing the floor like an idiot (I look up and see the newly broom launched dust particles under the workshop lighting!)
