woden":1htqeck0 said:Would you say that the Victor blades on Cliftons are every bit as good as the Lie Nielsen, Veritas or Hock blades? I just wonder if the Clifton cap iron is as good as the ground versions that are made by and unfortunately only fit Lie Nielsen planes. Are they as thick or as sturdy?
Colin C":3l426go6 said:Woden
When you buy a Clifton cap iron, it does not come with the screw
Paul Chapman":21oxs2ni said:Colin C":21oxs2ni said:Woden
Colin,
If you look at the Classic Hand Tools site, it says that the Clifton cap iron comes with an extra long screw http://www.classichandtools.com/acatalo ... lades.html
Cheers :wink:
Paul
Bainzy":2l7h31nq said:Did Record ever make a Bedrock style frog?
Tony":s704r7u9 said:Lovely and shiny, but how does it work? :lol:
The two piece cap iron actually scares me a bit, mainly because I can be a bit of a klutz and am prone to drop/walk into things if I'm not careful. Also, only the lower section of the Clifton CI is machined from thick steel and this almost seems like an admission of a lack of ambition when compared to the fully machined offerings from Lie Nielsen and Hock. The other seeming advantage of the LN blades is that they're even thicker at 3.75mm when compared with Clifton/Victors 3.1mm - isn't that about 16% extra if my maths is correct. I'm not trying pick holes in your choice but just doing a bit of research and pondering from a novice's perspective. :?Paul Chapman":1anqjt7l said:...I particularly like their cap iron and think it is one of the best designs available. However, some people don't like it - usually because they forget to keep their finger on the detachable bit when they remove it from the plane and it drops off If you look at the picture of Rob's renovated Record #4 it has one of my Clifton blades and cap irons in it temporarily until Rob gets his own. You will see that the blade is thick (3.1mm) as is the cap iron...
Newbie_Neil":mza46u2m said:Hi Tony
Tony":mza46u2m said:Lovely and shiny, but how does it work? :lol:
You should really wash your mouth out. You know you don't ask a c****ector such a question. :lol:
Neil
PS Rob, I'm sorry but I just couldn't resist it. :wink:
