Rod - which Camvac did you have? I had a close look at the big Camvac (about £320) at Yandles with the twin motors (100mm port) and it had plenty of suck..I was quite impressed. I wonder if the Record has more? - RobHarbo":takpcoaa said:I replaced my Camvac with the DX5000 as it could not cope with my planer/thicknesser.
Rod
Rod - yes, I saw that one as well. The guy said is would be OK for a general extraction system but probably not very good for a p/t. I like the idea though that there's a small 'footprint' in the 'shop compared to a two bag extractor. I was very impressed as well with the build quality so may well use the two motor version in my extraction system later on. I wonder though if you could use the twin motor one together with a 2hp table saw or bandsaw on a 13A ring main as in my 'shop?..overload? - RobHarbo":3vr8xwwr said:Rob - I should have perhaps clarified which Camvac I had - it was the small wall mounted one with the 2.5" inlet. It could not cope with the shavings from my P/T.
Camvacs are great extractors and very reliable - when I bought mine the Record was on special offer and much cheaper than the corresponding Camvac.
Rod
