Here are some modifications I made to my CL3 to make it a more likeable companion. There are a lot of these out there so someone might benefit. Apologies if they seem old hat.
1. Make and fit an oil retaining collar for the brass bearing.
2. Replace the pressed steel shaft spanner with a forged one. I got an off-set 25mm gas bottle spanner for £2.
3. Make a centre steady . The CLs have long spindle capacity.
4. Fit a handle to the tailstock wheel.
5. Make and fit a hand-wheel to the end of the main spindle.
6. If you still use the old style banjo (better but awkward to adjust) - I moved the lever to the top with an optimally
oriented nut below the bars.
7. Why bother with the belt cover screw?
More images on (newest) http://s77.photobucket.com/user/Leew_Fr ... t=9&page=1
