bp122
Expert at Jibber-Jabber
It is an old timer which needs a lot of TLC.
Please examine the photos.
It has been battered around over the years.
I tried to clean off the rust and paint it with Hammerite direct to rust paint, but I didn't do a good job of it.
I can't be bothered to work on it anymore.
Condition: It needs a split pin and a spacer to lock the threaded rod (large screw), When unmounted it sncrews all the way out without issues. But when mounted, it can't complete the last 80-90mm stroke for some reason. Handle has a small bend in it.
Again, I couldn't determine why, but someone with a bit more patience may figure it out.
Pick up from HP17 area. I'm around most evenings after 5.30 and most weekends. PM for details and availability.
£25 cash,
Thank you for looking.
