Hi all. Before I get shot I did search for this type of advice but could not find anything specific to this style building. What I mean is T&G all around.
It is like this one.
https://www.waltons.co.uk/4m-x-3m-walto ... -log-cabin
The walls are 28mm T&G and floorboards are 12mm T&G.
The whole building is on 6"x2" rafters which I am planning to keep off the ground on pilots, on top of which there are 2"bearers. The ground I will cover with vegetation proof fabric membrane.
I just bought this second hand, took is apart and moved to our garden.
My plan is to insulate then floor before I built it up again as the rafters are crossed with bearers which could make it awkward to do once bearers are reinstalled.
At later stage I am planning to insulate the roof and walls depending how I can save money for materials.
Would I need different type of roofing cover rather than present felt?
My main worry is condensation as a lot of my tools in past suffered with rust and I would rather to make something that keep de-rusting my tools and equipment.
For the floor.
I was thinking about putting some battens inside of the rafters. Putting some sheet material on them to hold the insulation in place and put floorboards down.
If required where do I install the vapour membrane. How thick the insulation should be? Any cost effective options?
Thank you
For the floor.
Thank you
