Yebbut were the chisel cut surfaces in sight? In any case you'd expect to get a reasonable surface in a long 6mm slot, with a chisel used carefully bevel down. Unless of course it has a micro bevel and is hollow ground! Not a good way to sharpen chisels for that very reason i.e. they don't work bevel down. Rounded bevel best here.
Digit":3blo23ge said:When I built the desk I'm working at. It has Pigeon holes made with 6 mil Iroko and I doubt that even you have a 6 mil bull nose plane!
Previous to that on a writing slope using 6 mil Beech.
Roy.
Jeff Gorman":1p6euset said:Coming very very late into this discussion, may I point out that no matter how carefully the sole of a plane is flattened, the plane's body can deflect.
There's some evidence on my site at http://tinyurl.com/7oeqdez
Just how it affects its operation is one of those imponderables that I too can't get my head round.
Jeff
http://www.amgron.clara.net
Cheshirechappie":10q8ezur said:Just a thought for the shaving-measurers. Your measured shaving thickness may not match the change in dimension of your stock. You force a shaving through a very considerable change in shape by planing it off, and it may well change it's exact dimensions as a result (most of them curl up, for a start!). If you really, really want to know how much you're taking off, measure your stock before taking the shaving, then after. The rest of us will just make our components fit each other.
Pete Maddex":3c4njt2r said:Cheshirechappie":3c4njt2r said:Just a thought for the shaving-measurers. Your measured shaving thickness may not match the change in dimension of your stock. You force a shaving through a very considerable change in shape by planing it off, and it may well change it's exact dimensions as a result (most of them curl up, for a start!). If you really, really want to know how much you're taking off, measure your stock before taking the shaving, then after. The rest of us will just make our components fit each other.
We don't measure shavings to see how much we take off, just to see how well the plane peforms, so stop having a go at us.
