Re; the 10 shavings = a hump; I think this should only be a problem if the plane is by some sort of machine. In practice, it's counteracted by the fact that the plane is held by a human being . It's just a question of technique, surely?
John Brown":j76tcgn6 said:Well, there's a lot for me to read here. When I asked the question I was explicity thinking of the situation where one is trying to obtain a straight edge for jointing boards, so I was picturing the workpiece being narrower than the blade. However, the replies have probably covered this situation as well as most others.
It'll take me a while to read and digest all of this, but in the meantime, thanks to everyone who has responded.
John Brown":58unsf02 said:Forgive me for having to ask, but I can't get my head round this.
On a power planer, even a hand-held one, the table, or the sole? in the case of a hand-held electric planer, is at a different height in front of the cuting edge compared to behind the cutting edge. Indeed, if I want to set up my router table for jointing, I have shims that move the outfeed fence relative to the infeed. This makes sense to me.
In the case of a hand plane, with a flat sole?(if I have the terms right) I would have thought that the piece being planed would end up with a slight curve, as the back end of the plane dropped down onto the section that had already been shaved.
Why is this apparently not a problem? Is the effect too small to matter, or am I missing something?
Hand held power planers cut a trench and could in theory precisely remove parallel trenches to flatten a surface, but only if it's flat to start with :roll: . But they tend not to be, and power planers are really difficult unless just removing stuff quite roughly - a powered scrub plane.David C":2yudxw1m said:BB,
I thought I had answered it !
Machine planers have the correct geometry to produce flat surfaces,.
It makes no difference and they are a lot easier to use, but slower!.the bench planes generally do not.
Technique yes, for both. Any effort to remove high spots is effectively a "stopped" shaving i.e. it starts and/or stops within the length of the workpiece.Technique and stop shavings are required.
David Charlesworth
bugbear":1aod968c said:John Brown":1aod968c said:Well, there's a lot for me to read here. When I asked the question I was explicity thinking of the situation where one is trying to obtain a straight edge for jointing boards, so I was picturing the workpiece being narrower than the blade. However, the replies have probably covered this situation as well as most others.
The question of how to make a flat surface using a plane has been (loudly) answered.
No-one has responded your interesting point about "flat soled" hand planes versus "step-soled" machines.
BugBear
how flat is 'flat'?
That reminds me - doesn't the #75 bullnose have the nose piece higher than the rest of the sole? Or so I've seen reported (often). Reported even more often is what an utter stinker the #75 is to use. Connection?Cheshirechappie":e0jxsu74 said:I can't remember where I saw this, but someone reported checking over an old wooden rebate plane, and finding that the sole ahead of the blade was a hair above the sole behind the blade, though both 'halves' of the sole were flat. Just like a machine planer, or power hand-planer.
I think it's probably fair to say that as either the planemaker or the person who 'adjusted' the sole thusly is more than likely making shavings in the great workshop in the sky, we won't know if this was deliberate or a happy accident, but it would be interesting to know how it affected the plane's performance, if at all.
Digit":2gx6d76b said:how flat is 'flat'?
The question I posed earkier. Flatening should be that which is required for the plane to work, beyond that is plain masochism!
Roy.
Alf":3gm6l52l said:That reminds me - doesn't the #75 bullnose have the nose piece higher than the rest of the sole? Or so I've seen reported (often). Reported even more often is what an utter stinker the #75 is to use. Connection?
Interesting. Makes sense.Cheshirechappie":1vlobpfu said:..........
Actually, there's an interesting parallel from the world of engineering. To file a surface flat, you don't use a file that's flat; a so-called 'Flat File' actually has a very slight belly in it - you can see this if you sight down the length of the file. So if you want to take off a very slight hump to leave a workpiece flat, you use the bellied 'flat file' with a bit of finger pressure on the area that needs attention, and the bellying of the file lifts the rest of the cutting surface very slightly clear of the surface. A 'Hand File' is flat, but won't file flat - the best you can do is to leave the work slightly convex. .......
Jacob":3g2r6qpm said:Interesting. Makes sense.Cheshirechappie":3g2r6qpm said:..........
I often wonder about the weird obsession with flattening chisel faces. Never made sense to me. If you want to pare a flat surface the chisel face has to be convex to some extent.
You can see the problem here http://www.youtube.com/watch?v=cOvkNuwO_YM
Rob Cosman doing a commercial for a very expensive diamond plate burbles on knowingly about flat faces etc but then completely fails to pare the end grain of his sample. He cuts a notch instead. Not that he seems to notice this himself!
Hilarious!
But what is the point of his demo? You could do that notch with any sharp chisel even with a back bevel or a totally convex "belly". Sharp pen-knife for that matter.MickCheese":3u79n9jv said:.....
Jacob
Am I missing something? I am sure he meant to do that, he even mentions cutting downwards. Are you just being deliberately obtuse? [-X
Mick
