AJB Temple
Finely figured
I use my Veritas block plane a lot. Its super handy for little trimming and chamfering jobs. BPs need to be really sharp and properly adjusted. If yours is digging in then adjustment may also be an issue.
Bm101":3fz7s1ls said:Sorry fella didn't mean to teach the sucking of eggs. Sometimes it's hard to gauge online. Was well meant as I'm sure you know. Missed the fact you already owned one!
Best
Chris
Agreed, there are many tools that you don't actually need, but are 'nice' to have none the less. However, a block plane is one you do (IMO) actually need, not only for the small jobs, but the bigger jobs as well where a big plane is just too unwieldy; thinking here about squaring up say, the bottom of a 50mm square table leg. Very difficult to do with a No.5 but using a small block plane makes much lighter work of it. Andy and others are quite correct; sharpness is crucial, especially on end grain material.AndyT":2f5hngbj said:Some good advice here. I'll echo most of it - yes, a block plane is nice to have but (as with many tools) you can manage without one. Things might be a bit more difficult or take a bit longer.
I like a block plane if I am working on anything small and fiddly. It's easier to see what is happening to the wood if there's not a great big lump of iron in the way of it. My preferred one is an old one; I suspect that a new one from Screwfix is probably a bit crudely made and might need work before it gave good results. That's not to say that all old planes are good - there always were lots of options so as to cover all possible price points and cheaply made planes that look superficially similar to the best ones are nothing new.
I've not watched the particular Rex Kruger vid that ED65 mentioned, but the ones I have watched I rather like - he does seem to be sensible and good at explaining things, not selling things.
Sharpness really does matter, but let's not make this another sharpening thread!
That would work":uro7um79 said:...... the low angle of attack suits the cutting of end grain.......
Indeed Mike! When you do the sums if the blade is honed to 30deg and it's got a 12.5deg bed, the ef (effective pitch) of the blade is 42.5deg - RobMikeG.":3o31uk9p said:That would work":3o31uk9p said:...... the low angle of attack suits the cutting of end grain.......
The blade of a block plane actually enters the wood at a higher angle than with a normal bevel down bench plane assuming both are sharpened to 25 degrees, so this theory about block planes and end grain has always amused me.
That would work":izu8pnb6 said:A smoothing plane has a frog set at 45 degrees? Minimum.
MikeG.":1faelqgt said:That would work":1faelqgt said:A smoothing plane has a frog set at 45 degrees? Minimum.
Correct. A block plane like the standard Stanleys and Records had a bed angle of 25 degrees, and add on the 25 degrees of the cutting edge, that's an angle of attack of 50 degrees...........5 degrees higher than a smoothing plane. 10 degrees higher if you hone to 30 degrees (which those who use a secondary bevel usually do, apparently). You would need a bed angle of 15 degrees to equal the angle of attack of a normal smoothing plane.......so I say again, block planes being best for end grain is a myth.
AndyT":sen51vzm said:.........you're going to have to buy another one! ;-)
Some are 25 degrees, mine is 12 degrees.MikeG.":3eqlsikg said:That would work":3eqlsikg said:A smoothing plane has a frog set at 45 degrees? Minimum.
MikeG.":33f29m67 said:AndyT":33f29m67 said:.........you're going to have to buy another one! ;-)
I haven't bought one yet! One was a skip find, and I think the other one was left in the garage of a house I bought decades ago.
That would work":pshkix0a said:.......Some are 25 degrees, mine is 12 degrees.
