Chrispy
A few days ago I mentioned reaction wood in a answer to a query which got me thinking so thought I would start a thread on the topic, please feel free to correct me if go wrong :lol:
There is I think two main kinds of reaction wood, that that is in compression and that that is in tension.
It can be found in the buttressing around the base of large old trees, or where a tree has been pushed over by land slip or being leant on by another fallen tree, it is also found in branch wood.
The job of this type of wood is to support the weight of the tree and to return a leaning tree to a upright balanced standing.
You can sometimes see it as an extra layer between the spring and summer growth rings, especially on a horizontal branch.
If you have a plank of wood that is very bent it is almost sure that is due to reaction wood, and as soon as you cut into it it it will move even more binding on the saw and leaving a woolly cut due to the fibre of the wood being in great tension or compession.
This is sometimes in error seen as bad drying.
As far as I believe you find tension wood in softwoods and compression wood in hardwoods but l may be wrong.
hope you find this useful.
