Raised Panel
Happyness66
New member
7 Aug 2024
Norfolk
Can anyone tell me what kind of joint this is, and will it hold a raised panel together in and external hardwood door. It seems to be separating after just being delivered?
    106.5 KB
Not really sure but think I would call it a bead edge joint, a kind of tongue and groove that should keep things in line and increase the gluing area.
You can clearly see the join which isn't great, a bigger photo might help see what's going on.
Is it Oak, it all looks a bit rough.
It's sapele. The door is primed, yet to be painted. He also just told me to caulk this gap above the left-hand panel which is 15mm deep. I'm worried about water ingress. This is the second door he's made, the first one the panels split within 3 months because he only biscuit jointed them. Do you think these panels will just split as well? South facing door, no porch, exposed to elements. Thanks for your time.
    2.8 MB
    4.9 MB
    4.1 MB
    3.3 MB
