The normal profile for Raised Panels (RP) is that the part that sits in the stile/rail is a parallel section ( hence this profile on router cutters) to allow for movement. I have seen a number of examples particularly those that are cut on a table saw and by hand plane where there is no parallel section just the tapered edge, how can this work?. If the panel expands it will just lock up against the taper, if it contracts it will just fall out unless it was a very loose fit to allow more of the taper to enter stile /rail, but it would then rattle.
