Question about zero clearance Table saw insert.
Britman
Chip of the old block
25 Dec 2020
UK
So bought a zero clearance insert for the table saw and I've noticed that in the middle to the right of the blade its got a scoop taken out. So at that point it's not level with the left side. It's only in the middle of where the blade comes through
Is this normal for this type of insert?
    143.6 KB
Yup, that’s rubbish. They are pretty easy to make. Just a piece on wood fitted to the hole, screw in each corner to level. Fence over the top to hold in place and raise the blade up cutting through the insert. Remove and extend slot for the roving knife.
Fitz.
My blade does not go below table? Got a smaller blade but kerf thinner. Any suggestions
what saw do you have that the blade can't be completely retracted when not in use? I've never seen a saw that doesn't, so I'm surprised they exist. this is a genuine question not a remark about you or your abilities or knowledge or anything else, it's just a question about your saw as I'm surprised and want to learn more.
While my blade retracts below the surface it does not retract enough to be below a ply insert so I take the blade from my circular saw to start the cut. As long as it's the same kerf as the main blade it works fine.
Regards
