Allylearm":31xjihtu said:Don't like plastic, they sit on my new supplied machines, and that is where they remain. I have found like everything else in woodworking, you can get as many thoughts on everything you will ever do or want to do, you work out what suits you best or is as hand at the time.
I prefer myself birdsmouth cuts to push the timber, I also like to combine a pusher on the end or flat surface to keep timber against the fence for example. I also use alot of spring fences on my spindle moulder. The important bit is it keeps your hands and fingers away from blades/cutters. Stay in the habit of using sticks when ever you push wood through. Its a habit that will save you a digit and feeling so stupid after it happens.
YOu're scaring me.
I have not the slightest intention of loosing one.
I have used the sw very little .....I question if I want to now.
My Dad says of the hand held circ saws....he uses one if he absolutely has to, but it's a last resort. Maybe I find another way, I ran it up today, it's just too severe.
