billw
The Tattooed One
With the first coat drying on the saw vice I can't crack on with sharpening any saws yet, but I do have a half-finished wall cabinet that needed a door and a finish applying. I did have a door design in mind since the carcass is actually half of a project from F&C, but I don't have any 10mm PAR that's large enough for that design. In addition the workmanship on the carcass is basically cr*p, so it really isn't good enough for anything other than a shop item - and I'm adept at cutting myself so having some plasters and TCP to hand will be a bonus.
So, I'm starting off with this, made from American black walnut and bog oak for the back and dowels.
You could drive a bus through those gaps, thankfully they're all going to be against a wall.
This morning I rough cut the door from a piece of 10mm bog oak that's fortunately just about big enough to make the door. My initial thoughts were to inlay a cross into the door to signify its first aid usage, and I have three suitable offcuts to do that from - sycamore, padauk, and purpleheart. I know the latter two will eventually fade to brown but since the cabinet will be in a workshop that will probably take a fair while, and I could always try the suntan lotion trick to give some UV protection.
Alternatively I could make it a 3D affair and chamfer the edges of the cross.
As for the handle, I've cut the door a little long and was thinking of having a small handle extending out from the bottom of the door itself so it could be flicked open using one finger, helpful if you're bleeding to death I suppose. I already have some brass hinges and a paid of magnets to keep the door shut.
ps yes the bench is riddled with woodworm holes.
