LoveForDIY
New member
Hello all - I am new here and came across this forum searching for a way to build door frames and attach it to a stone wall.
I have previously restored older doors (images for examples) but the doors already had a door frame and I could simply put the door back together.
now, I have not built a door and door frame from start to finish and this is where I need some advice.
The above image is where my door & door frame will go. My questions are:
1) what methods do you use to attach your wood door frames to stone walls?
2) what type of wood would you use to build the door/door frames? ( I would like it to be inexpensive and was thinking of pressure treated pine but please inform me if this is a bad decision for any reason)
3) since this is my first time doing this, is there any advice or knowledge i should have or do research on before starting.
