dadiy":qgra8m5a said:Interesting - I have a 1/2" bowl gouge but I assumed as its a lot smaller than the 3/4" roughing gouge that it was too small and weak for the job.
I have the Crown 'Axminster' Turning Tool Set which included both.
dadiy":1xx44ili said:Interesting - I have a 1/2" bowl gouge but I assumed as its a lot smaller than the 3/4" roughing gouge that it was too small and weak for the job.
Bodrighy":81ymtbrl said:You can use a bowl gouge on almost anything due to the way it is made. Look at the blade and shaft and you will see that it is solid bar drilled out whereas a spindle gouge, including a roughing gouge is forged to the shape.
loz":1jw26scw said:Bodrighy":1jw26scw said:You can use a bowl gouge on almost anything due to the way it is made. Look at the blade and shaft and you will see that it is solid bar drilled out whereas a spindle gouge, including a roughing gouge is forged to the shape.
hiya Pete,
I'm pretty sure my spindle gouges are milled bar's exactly the same as my bowl gouges. but I'll have to double check now !!!
Being very PC about it I'd say at least before the first cut and again before the last one, and several times in between if the wood thinks it's boss.dadiy":wn3m9e4e said:...... How often do you guys sharpen?
