graween
Hi,
Thanks Mathew for the intersting reply.
I still though think about 2 things that come to my mind. That I'm sure you could help me with or correct if I'm wrong.
1-To keep the advantage for the very slight hollow grind, one must lay the full blade length on the abrasive when removing the burr. That means long abraise stones.
2-Does this means that when you do precise work on short length, you might have to lift a little the handle (because the hollow laying flat on the work, means that the shiny very narrow lower cutting part is at an angle, and the edge kind of lift up, classic problem of paring with convex chisels) ? Or does a 4 thou hollow make this fact neglectable ?
Thank.
PS : I hope I'm clear, cause English is not my mother language
Thank.
