Precision machined bar
Ian
5 Apr 2007
Northern Ireland
Hi
Can anyone tell me where I might get a 500mm lenght of precision machined aluminun bar.
I hoping to make a jig for use on the router table fitted with a flush trim to produce very straight edges.
Ian
Ahh, I thought you were looking for a specific size...
Have a quick search on ebay using "aluminium flat bar"
Si.
It's worth noting that flat stock is not necessarily straight, it can be very accurately dimensioned - i.e. a section taken at any point will be exactly 5mm x 20mm but that doesn't mean that all of those sections are perfectly aligned - as they are in a straight edge. (otherwise we would all be using lumps of flat stock as straight edges).
I don't want to pour cold water on your idea, but it might be worth investigating cheap low accuracy straightedges too.
I see your point but if say glue this flat stock to MDF and a bearing of a router bit follows it will it not produce near perfect straight cuts.
I think as long as it is say 3mm thick along its lenght it should be ok or should it :-k
cheers
If I were going to introduce tungsten carbide moving at woodworking speeds to anything it wouldn't be made from any kind of metal. You can get aluminium cutting tools that are made from TC but they operate at much much lower speeds. A piece of accurately planed boxwood would be safer and probably no less accurate if you are gluing it to MDF.
This will be a top guided bearing trimmer so the only thing touching the metal will be a portion of the bearing.
Ian
I think aluminium would be the wrong choice, too soft for a bearing surface and you would probably wear a groove before long.
