The other thread has gone sideways with discussion about what's possible or practical from people who haven't done or measured anything.
Last year, I got an older plane out that I'd set aside because I dreaded the amount of physical work to fix it. IT was a very heavily worn (not defective, but worn into a twist, I guess by someone jointing edges with it on dirty wood), as well as toe and heel high.
This plane was expensive for me (it's uncommon - a norris no 13 that's 15 1/2 inches long). I didn't feel like addressing it right away but it couldn't be used for any kind of work that was close to smoothing or flattening.
Because this can be hard on fingers, I split the filing over a couple of sessions (if you do 20 minutes of the filing out of the center of a plane, you will remember it). It could've been done in one, but it's nice to make it pleasant and think vs. rushing through all in a row with blisters.
If I ever sell this plane, I may finish filing off another 2 thousandths of sole so that I can show pictures of it. The very tail of the the plane and a tip of the toe is 2 thousandths high. measured with a starrett 380 and a feeler. The rest of the plane doesn't come close to allowing my thinnest feeler - .0012" - no matter how you orient the straight edge - straight up and back from side to side, or on the diagonal or across it.
This is probably the worst plane for flatness that I ever bought, and twist and convexity is the most difficult combination.
There's no way the total time spent was greater than 2 hours, and I figure it's more likely to have been around an hour. I don't remember and would have to track down the post on another forum to remember.
If this were lapped, it probably wouldn't turn out well.
These files are $9, by the way, and the paper is just PSA roll. The only thing expensive is the straight edge (and the plane).
quite often, the smaller bailey-type cast planes take about 20 minutes to lap and they're very close to this. Sometimes it's 5.
If you think you'd like your common plane to work like an expensive plane in fine work, this is the part that's generally missing. Sloppy adjusters, blades not made of "a2" or whatever have nothing to do with it.
