powerline bandsaw bbs 20 mark 2
Thank you all for answering and helping.
Since you have a similar device would you be kind enough to help me in the following questions?
What is the right length of the blade in the catalogues it is written the length 1435 mm. I gave the device to a repair shop and they installed a 1446 mm length blade. What would be the correct length or does this device allow all sizes between these measures?
What is the thickness of the material it is made of?
In the device I got the 4 wheels (stoppers) are not connected to the body of the device.
Would it be possible to have a picture, drawing, explanation on how they should be attached, connected?
Does the blade on its back side need to pass through the slot of the iron wheel?
In my country it is difficult to manufacture 0.014 inch blades, I can manufacture iron wheels identical to those I have, in which there will be a slot that will allow 0.025 blades to pass trough. Would it harm or be problematic for the device to work properly?
Do you happen to own a user manual?
Thank you very much for your help
Elkana
