StunningHere's yesterdays effort from an Ovangkol disc that TGW had bought for my Birthday but only just got round to turning it. Sanded to 600 then 2 coats microcrystalline.
BeautifulThis morning's offering is a footed bowl made from some confused chimp
View attachment 164978View attachment 164979View attachment 164980View attachment 164981View attachment 164982View attachment 164983View attachment 164984
I like this idea a lot and may steal it!I thought this would be simple enough to do, but what a pain in the backside it turned out to be.
I had a plastic cup that I'd been using at work, one of those thermal types with a thin metal insert and I thought I'd have a go at making a nice wooden cup and re-use the old insert. I wanted to use a piece from an old Oak fireplace, my first issue though was the amount of cracks in the wood! I ended up with a blank that was just large enough for what I needed, but there were still some cracks.
Problem no 1, while turning a cylinder, I had a catch on a crack and a fair sized chunk flew off. Superglued back on, although I regret having used accelerator on it.
Problem no 2, I made a recess for the chuck, thinking this would be the best option and I could use the recess as a foot, making the most of the limited amount of wood. I mounted it on the chuck, you've guessed it ... the wood split and I ended up removing the recess and making a tenon .... further reducing the depth of the wood.
Problem no 3, I was just about done and I only needed to push the insert in an extra few millimetres (which up until this point I'd avoided), yes.... it split the wood and I had to fill the large crack with milliput and sand it down some more.
Lessons were learned for next time, overall though I'm pleased with the final result.
View attachment 166178 View attachment 166179
View attachment 166180 View attachment 166181
My apologies Padster, I meant to reply to this sooner and forgot all about it! I read your reply on my phone while out at work and I intended to reply once I got home.I like this idea a lot and may steal it!
So....
Does the cup keep the drink as hot as before or has some of the thermal functionality been lost - lack of vacuum?
Was it easy to remove the original external plastic?
Where did you get the cup ;-)
Regards
Padster
Maybe bandsaw through the crack and make two mini bowlsSome advice please.
Started turning some Cedar and noticed this split opening up.
Now should I bin it, rough turn the inside and CA glue or wood hardener.
View attachment 162789View attachment 162790
Tis a thing of beautyI've had 3 Sycamore logs sat at the back of the pile that we're cut about 4 years ago, 2 are about 2ft long and a smaller one about 18inches, all are about 11inch diameter, they're split all over and really should be moved to the fire pile but this morning I was feeling brave/stupid so using my electric plane I reduced the smaller log down to about 9inch diameter so it would fit on the lathe and went to balancing it with the roughing gouge, it's so punky I had some large pieces tear out so I moved over to a fresh bowl gouge which gave a better cut although still had loads of tear out, got it shaped close to finish and saturated the whole thing in CA glue then took a final pass and got a really nice finish, then turned it round and put it in the chuck, having no steady rest made hollowing a nervous affair so I only hollowed what I could without it flying off. Whole thing sanded to 320 then abrasive paste and hard wax, the inside is sanded at 80g on a stick for what I couldn't reach by hand. Overall I'm glad I took the chance
Need to start looking at hollowing tools I think.
View attachment 165032View attachment 165033View attachment 165034View attachment 165035View attachment 165036View attachment 165037View attachment 165038
these look well cool fella now my wife is nippin my head to do a similar pair lol just as well I enjoy segmented workA pair of complimentary Wanut/Oak lidded pots.
View attachment 166117View attachment 166118View attachment 166119View attachment 166120View attachment 166121
nice tidy bowl using cutting m8 we always find a way to get something to turn without using the good stuff I have a burl I bought 3 years ago still waiting for my attention, I started with the same lathe as you it was a reliable and quiet lathe, take your time and do research before you pull the trigger on bigger or better lathesMy first bowl since high school 50 years ago. Now retired I thought it would be nice to get back into turning.
Just as a start I glued pieces of hardwood together so if it didn't look OK I wouldn't waste a block of hardwood.
Quite pleased with the result!
6.5" diameter bowl but it is only a Record DML24 lathe to begin with. If I get the bug I may invest in a larger machine.
I have the same lathe and almost 2 years on I'm starting to feel restricted, don't get me wrong it's a beautiful lathe and perfect for starting out and learning I just want to have more control over speed and be able able to turn bigger stuff, also I'm quite lazy so having to reach for a spanner every time I need to adjust the tool rest or tailstock is becoming an irritation.My first bowl since high school 50 years ago. Now retired I thought it would be nice to get back into turning.
Can't you replace with Bristol levers that's what my cl1 hasI have the same lathe and almost 2 years on I'm starting to feel restricted, don't get me wrong it's a beautiful lathe and perfect for starting out and learning I just want to have more control over speed and be able able to turn bigger stuff, also I'm quite lazy so having to reach for a spanner every time I need to adjust the tool rest or tailstock is becoming an irritation.
I could but that doesn't solve my main issue of wanting to turn bigger, trying to save for a bigger lathe so don't want to spend money on something that is just a convenience, as well as lazy I'm also tighter than ScroogeCan't you replace with Bristol levers that's what my cl1 has
