Couple of planes on the way.
Posting because I think they look nice at this stage, with their bed and escapement cut.
Mortises and wedges….
What did you turn it on?Just another "what is it?", or to be more precise - "a whistle tuning slide". I couldn't find any to buy, so I've had to make one. This will be fitted in the wooden whistle tube, midway between the mouthpiece and the top fingerhole. This is the MK1, as I'm sure the design will change as I go along.
Photo 1, The two separate parts.
" " 2, Both pieces slid together.
" " 3, Slightly apart as it should appear when the whistle is in tune.
Interesting. If you have a metal lathe why not turn it as 2 pieces? Looks like a fun little project.Not so much turned, as fabricated from telescopic tube - apart from the rings, that were parted off, from a larger tube on a metal lathe
The rings are silver soldered to each end of the outer tubes, and the thin, inner tube ( a loose fit at the moment ) will be superglued to one of them, though only after the slide has been fitted to the whistle body.
Seen a few tensegrity tables on YouTube, love them but not sure I'd have the patience or finesse to pull it offView attachment 167129View attachment 167130
It's a prototype for a table. The supports are boot laces. On the table they will be loose link chains or soft chord.
Fair enough, 1/32 is very thin.Well beyond my capabilities and those of my lathe, to turn two tubes with 1/32" walls that will easily slide inside each other. Better to purchase from a specialist firm, two matched tubes
Looking good, my next big project is going to be a coffee bar, love how clean yours looks.A bit more progress on the bar, a half arch with halo lighting. Made from MDF.
Front for dishwasher still needs to be done.
What does the larger one weigh?A couple of sterling silver ferrules
They turned out pretty well. Hope you will show us the finished whistles." A poor thing but mine own" A couple of sterling silver ferrules. They've not turned out too bad.
There is a bit of a blip on the solder joint of the larger one, but luckily, this will be cut away on the finished whistle.
About 17 GM, the smaller, 4 GM which equates to about £ 18 though one does have to purchase slightly more than one needs to get the sizes out.What does the larger one weigh?
There might be a bit of a pause, before I commit to using the silver. as, I'm still experimenting to get a better sound with the others I'm making.They turned out pretty well. Hope you will show us the finished whistles.
