Working well on the few tests I've done, not used them in anger yetHow are the clamps (mid right)?
ThanksWorking well on the few tests I've done, not used them in anger yet
I've stick a sheet of ply onto a block of oak!Started another piece on the lathe today, it's a piece of the cherry I've had for about while, if it turns out well enough it will be an Xmas gift for a friend.
Actually no, this piece is end grain, its a little more work intensive to hollow out but the grain figure in this cherry is absolutely beautiful and worth the extra effort, I do have another piece that I started turning side grain, once rounded off its very slim so will likely be a vase of some form.I've stick a sheet of ply onto a block of oak!
Ready to turn!!!
Presume you turn side grain across the bowel?
Cheers James
Oooooooo ouch, I caught my right hand ring finger while sanding, gave a shock, bit of a scrape nowt bad, darnt tell hubby in case he took power tools off me lol@Yorkieguy those are beautiful. From the roughing gouge my blanks are very rough and almost abrasive, so much so that it caught the meat of my hand and bit me as I was pulling along the tool rest and dragged a chunk of the loose skin in between the wood and the rest.
Looks worse than it feels but it certainly woke me up![]()
All my cherry blanks are from one trunk cut into sections.
The 2 pieces of spalted birch on the left are so far gone that I can't cut them no matter how sharp my gouge is so gonna have to get them stabilised before I use them.
There's a reason it has the nickname of IronwoodI tried turning some oak not a disaster but a wake up call not to run before you can walk!
Chips like anything and blunts the chisel like nothing else!
I'm going to stick to softer woods I think!
Cheers James
... silver birch is nice to turn when it's green, it goes punky very quickly if not stored.properly though.
Yeah it's stunning, I have quite a few pieces but they have gone too far so now I need to look into stabilising so I can cut them rather than tear them apart. I even have a couple that I've left completely natural on the outside, hollowed out by hand and lined with resin to turn into plant pots for my huge spider plantsIt spalts beautifully.
Cheers James
I'm no expert but I must agree with the comment from Orraloon. I use seasoned and green Oak along with anything else that comes my way and I don't find problems with tools blunting particularly quickly with Oak and I get a much nicer surface from the Oak than soft woods. I am rather reluctant to sharpen the gouges too soon, as I'm worse at sharpening than turning but that's another thread.I tried turning some oak not a disaster but a wake up call not to run before you can walk!
Join the club.I'm starting to feel inadequate!!!
Cheers James
Yes. Way to far. Obviously with a shaped piece sometimes it'll be that far (and further) away, but it should be as close as possible.Oh great perhaps i had the rest too far from the wood? 1"??
Felt dangerous when it caught!
Cheers James
