Finally got the front door finished. Really pleased I chose to renovate rather than replace. Took way more hours than expected but should be good for another lifetime.
Jobs done:
- Removed old mortice lock, found the internals were missing so any old bit of metal could have opened it. Had to shim the mortice for the modern lock.
- Removed old vertical letter box, routed opening to an accurate shape and glued in new piece of Doug for. Split a 5/8 oak dowel to match the beading.
- Routed and fit new horizontal letter box.
- Sized an glued new strip to side of door so it filled the frame better.
- Removed, stripped and repainted the hinges and hinge screws. On one hinge I updated the screws but I don’t like to look so needed to find replacement slotted ones.
- Removed and repaired several trim pieces that were loose and/or split. Thankfully none so far gone that I had to remake them.
- Removed, stripped and repainted the wether bar.
- Sanded, filled many holes, undercoated, filled more holes, more sanding, more undercoating, sand, coat one, sand, finish coat.
- Removed, stripped (sympathetically), buffed, all door furniture. Managed to retain plenty of patina. Refitted.
Fitz.
