John15
Very attractive Pete. I like the finish very much - is it with a gouge?
Pete Maddex":xqtsycb8 said:Thanks chaps.
The bowl is sycamore and the spoon is cherry, finished with a sharp gouge, there is a weeks worth of roughage in a pinecone ;-)
Pete Maddex":rnuvovee said:Not the last thing I made but a couple of things I made a while ago, taken as part of my photo a day for a year project.
7th February by maddpete, on Flickr
mseries":rnuvovee said:
Yes it is, it works pretty much the same way. The crescent shaped transparent 'ends' slide in and out. Width is static but cutter/guide bush combinations allow different thickness tenons. it works, not perfectly, I'll need to tweak it a bit but sufficiently to keep me thinking about it.n0legs":1x3b2oan said:Looking good =D>
Is the jig variable like the 'dnerT' one ?
I rather like the shape of that. As above, monkeybiter, the colour is not to my taste but I could see it working in some locations.mouppe":52kbcrmt said:Windsor barstool. Distressed milk paint finish.
Thanks for posting that mouppe. It is interesting to see different working methods.mouppe":bsrwzzfc said:Uh-oh looks like unanimous thumbs-down to the finish so far! I can always sand the seat down and re-paint it, and may do so. I wanted to go for a distressed look because the chair will probably get a lot of wear and tear in the workshop. Over time, the two colours should blend better.
I have some work-in-progress photos to show how I carved the seat. First, I drew a contour map on the seat and routed out various depths using a router sled. Then, I used a #7 gouge to do most of the work, and finally sanded it smooth (not a lot of sanding was necessary). The front edges were shaped with a drawknife and spokeshave. The seat carving went very quickly although I would have used an adze if I had had one. I've done it that way before and it's a lot of fun.
Dimmaz88":1lzegdwi said:I love that milk paint finish. Not everyone want plain wood!
Is it a couple of different colours used?
