thetyreman":30q5ylsq said:
the interior needs to be able to stop the mic from being able to move around, I was originally going to go with felt but it may need some kind of soft lining under fabric, any advice would be appreciated
I did a WIP a few months ago showing how to line a box with suede. Suede is adequate for jewellery boxes. For a microphone I'd make a couple of "bridge" components, bearers that run from front to back and are shaped precisely with curved cut outs to receive the microphone. The trick then is to use the suede from the neck and armpit areas of the pig skin, suede from these areas is very elastic and can be shaped to conform to compound curves. You'll work this inside the cut outs, folding it 6mm down onto the flats. You'll then cover the flats with suede (it will actually be suede stuck with double sided tape to card) to within 3mm of the cut outs, the card is stuck on with Copydex. Read the WIP and it'll all be clear, it's a bit fiddly but it's not particularly difficult, and it makes the job look really professional.
