chrispuzzle":24ymzqr2 said:The drawback to a C-arm is, of course, the tendency to undercut, which for puzzlers and intarsia work means you must have a wide enough kerf to overcome the undercut or the pieces will not fit properly - in turn, that means you get a theoretically looser fit. Although with 4mm or 6mm ply puzzles it's not a big deal, I think with thicker intarsia work and some compound cuts it would make more of a difference - Gill? You do a lot of this sort of stuff?
I've never used a C-arm so I can't speak from personal experience. Logically, what you say should be true and it is backed up by Zachary Taylor in his Scroll Saw Bench Guide:
- Whether or not it is desirable to have the saw blade reciprocating vertically rather than with a slight backswing is dependent on the type of work to be undertaken. If, for example, mostly straight lines or gentle curves are to be cut, a C-frame scroll saw will perform as well as, and, in fact, more aggressively than a parallel-arm saw. The later is more efficient for the navigation of tight curves or smaller radii and, in general, leaves a better finish in the process. It is possible to work on small radii with a C-frame scroll saw provided the workpiece is relatively thin; otherwise, if thicker material is being cut, there is more strain on the blade, and also the finish suffers.
Gill
