frogesque
Problem:
My old Myford ML10 lathe would originally have been fitted with flat belt cone pulleys for changing speed (as well as the usual back gearing) giving 6 speeds in total.
Someone (not me) has changed the flat belt set up for standard 1/2 inch cone pulleys on the lathe spindle and the lay shaft. As well as not matching diameters, meaning the tension needs adjusted for every change, the belt is too thick to get past the middle stud nut on the the headstock. A total pain!
Anyone any experience of using poly V belts (the thin flat ones with mini grooves) and either obtaining or making cone pulleys to suit?
To date, the headstock bearings have been replaced (split tophat oilite bronze bushes), backplate made for a top quality 4 jaw Pratt chuck and I've some work still to do on the tailstock that appears to belong originally an ML7. I like it because it has a cam lever for locking to the bed and the normal offset for taper turning. Unfortunately the centre height is off to the headstock and I've shimmed it meantime but the toolmaker in me will probably make a new shoe for it. I've also sourced a reasonable set of change wheels for screw cutting but the thread dial indicator is missing - another wee job that needs doing!
