BigShot
Hi folks,
Imagine a bit of plywood with the edge (where you can see the veneers) hit so the wood bulges making the board thicker around the point of impact. The bulge goes about half an inch into the board before it's back to original thickness (and presumably undamaged). That's what I've got to fix.
I can't tell if the glue lines have split or the veneers themselves, but as I see it the way forwards is to get glue into the damaged area and then clamp it tightly enough to return it to the original thickness. Question is - how do I get glue down in there?
Would thinning wood glue with something (water?) be a good idea?
I'm using Evo-Stik Weatherproof Wood Adhesive if that makes a difference.
Where the damage was different (veneers split apart) I opened the gaps up with a knife, worked glue down into them and clamped up which did a great job... but there's no obvious gap to open up here.
Any suggestions of how to go about this would be handy.
Cheers.
Cheers.
