Trebor
New member
Hello,
I will shortly be buying a plunge saw and rails, mainly to cut down sheets of plywood and MDF. I have shortlisted 3 saw - Makita SP6000, Festool TS55 and Bosch GKT55. I want the ability to do cuts of a maximum of 6' and other lengths including 4' and 2'. I can afford any of the saws. Questions :-
1) Are there any real differences in cut quality between the 3 saws - blades are kind of universal in that any one of them can have a blade from several sources. Do any of these saw make better use of their rails/splinter gaurds that would give any less splintering ?
2) Never having used a rail based saw I am unsure of the minimum lengths of rail that is desirable. If cutting a 4' ply panel ( actually 1220mm) what length rail do you need so that the saw is fully supportedby the track at the start and finish of the cut ?...and does it make any difference (quality, safety etc ) if the cut is started with a plunge into the material rather than being clear of the material and plunging into thin air before running the saw forwards ? A mid-size rail from Makita is 1500mm, from Festool is 1400mm and Bosch use 1600mm. Bosch rails are unique ( to themselves and Mafell) but I could buy a TS55 from Festool and rails from Makita if the extra 100mm on the rail made a difference.
3) Will the lack of a riving knife come back to haunt me if I choose Makita or Bosch. Given the use I will put it to I suspect not.
4) Do the rip cut fences made by Makita and Festool do a good job ? Several of the projects involve making a lot of 2, 3 and 4" strips of material. Anybody know what width they will cut up to ?
5) The standard 48T Festool blade seems to be well liked. How do other brands of blade stack up ? Are the standard blades supplied by Makita and Bosch also good quality ?
and finally ( for now ) 6) The Bosch rails have a very neat joining system that appears to work well but the rails only have very narrow 'grippy' strips on the bottom - does these slip any more often that those from Festool/Makita that have much wider strips ?
Thanks for at least reading this far. Any pointers gratefully received.
Rob
Rob
