dedee
Can anyone help with a kitchen plumbing problem?
I've just discovered that when I empty the kitchen sink at the same time as the DW is being emptied that water comes up the vertical pipe thet it (DW) drains into
The DW is to the left, sink in the middle and WM on the right. The waste flows away to the left.
I've checked all the traps and they are very clean. I've run a flexi-shaft cleaning device through all the pipes both in the kitchen and in the garage underneath and all appears to be OK.
I suspect that DW waste cannot break into the faster flowing rush of water from the sink.
Is there anything I can do to prevent this happening again?
Would having the sink waste on the left (down stream of the DW) and moving the DW to the middle have any effect solve the problem?
cheers
Andy
![DSCN6815.jpg](https://proxy.imagearchive.com/600/6006c1b35e2812b2ca989e7aa31cf85d.jpg)
cheers
Andy
