Guys,
I am adding another radiator to my existing central heating system. The new rad I am fitting has a special value inside which dicates how I should connect the flow/return pipes.
The problem is, I don't know which pipe is the flow and which the return. I have already cut pipes and removed another rad, so I cant even fire the system up and see which gets hot first. Silly me.
I have turned the fill-tap located near the bioler that presurises the central-heating system up with water, and I can see that one of the cut pipes gushes, so I am guessing this is the flow. Is that def the case, or could it be that pipe is gushing because its lower that the other etc etc....
The other reason why I am still doubtfull is the TRV value his been fitted on the other pipe. I always thought they should be stuck on the flow pipe, but maybe the previous plumber just stuck it on the return side as its easier to reach ?
Any advice would be good?
