dedee
Can anyone help me to find an end cap to fit this:- or even help to explain the technical term for its size.
This is the valve from a 1000 litre tank I acquired over here. I'd like to make it a bit more user friendly and attach a hose pipe to it. Unfortunately it seems to have a "non standard thread". The only adapter I can find over here to fit has been quoted at €39.00 - more than the cost of the tank. The problem is the thread size. The cheap adapters, from €6.00, have a very course thread. The one on mine is very fine, i hope this picture shows the thread spacing of about 3mm with a thread depth of about 2mm. The outside diam. is 60mm
I have a brass tap with a thread and nut which I could easily attach to an end cap - if I could find one!
cheers
Andy
![DSCN5909.jpg](https://proxy.imagearchive.com/522/5227e9a67aaae949e2337f54ef9859b6.jpg)
![DSCN5910.jpg](https://proxy.imagearchive.com/6ff/6ffb24ccdffd8dbc1af481a762420d17.jpg)
cheers
Andy
