as one of them magicians who make plastering look like child's play, leave that one coat rubbish in the shop,
if your walls are solid brick use sand and cement backing render, if cavity walls and you are only doing a small area then use bonding,
wet up the brick work first and the edges, lay on thin coat over all the area, lay on the second coat and rule off to finish height,
as the backing coat sets float it fill in small holes, this should leave it a little low on a patch area,
on a patch, cut back your edge with your trowel to leave a little step 2-3 mm, wash existing plaster clean with your water brush,
keep these edges clean as you skim your patch.
sand and cement skim next day,
bonding, what you lay on in the morning skim in the afternoon.
what I call polishing is only done to p-off the decorator :twisted: , a polished wall won't take paint.
