Hi all,
I've done quite a bit of research on this but still not clear. I believe a surface planer is what our US cousins will call a jointer, and this has cutting blades on the bottom and is designed to create a smooth planed face and I think at 90 degrees to the edge.
But a thicknesser has the blades on top, and will plane the top face consistently to the same thickness.
Do I need both? I'm looking at using construction timber (sawn untreated) and also pallet timber to use in other items. I saw one video on the Triton side which suggested I should ideally have both, and their machines look pretty good, so maybe that's the way to go.
Or do I just use a thicknesser on all four sides?
Any advice and guidance welcome.
