Hi DW,
Tony has a few ideas on how to minimise it, look at his recent thread.
However, FWIW, here's my take on snipe.
Love and marriage, horse and carriage, spaghetti and bolognese, P/Ts and snipe.
A P/T has two rollers which press the timber down onto the bed. These are sprung, if they weren't, you would have zero tolerance as to the thickness of board presented. As long as they both keep the timber pressed down, you won't get snipe.
The problem arises when the weight of the board hanging out of the machine is more than ONE of the rollers can handle. The weight pulls the board down, thereby forcing the other end (no longer supported by the infeed roller, and heavy enough to flex the sprung outfeed roller) up into the blade. The only way to prevent it is to support the wood so it doesn't fall at all as it comes out (or goes in, of course).
Does this help?
Steve
