iNewbie
No hole my side.
That's not what Ed's said. He's tested and found there to be little difference in his tests between the different planes. Given that, it makes little sense to spend more on the 'premium' brands if they don't deliver anything more for him.iNewbie":2alc6dcg said:If you feel that way -that its about money- buy a wooden one.
Rhossydd":1jqh6s92 said:That's not what Ed's said. He's tested and found there to be little difference in his tests between the different planes. Given that, it makes little sense to spend more on the 'premium' brands if they don't deliver anything more for him.iNewbie":1jqh6s92 said:If you feel that way -that its about money- buy a wooden one.
Wooden planes are different issue and not relevant to this test.
Not really relevant. The only wooden planes(ECE) with similar convenience of screw adjusters for depth of cut and blade attitude are no cheaper than the equally well performing Chinese models.iNewbie":1m8mi7k9 said:if yer considering theres not much difference and savin' funds is a thought then get a woodie.
Ed Bray":x54ei08p said:Wow, I go to work and look what happens. Good job I didn't go on about sharpening lord knows where we could have ended up. :roll:
Rhossydd":2vptsigb said:What sort of criteria will you choose to judge it by ?matt_southward":2vptsigb said:I for one would never have thought to compare shaving thickness
Not trying to make waves, but shaving thickness seems a reasonable criteria to me. Given the right test equipment, at least it gives some sort of objective results.
Corneel":8zegnpqq said:You've still got a long way to go! :lol:
Absolutely, but surely the two are inextricably linked ?matt_southward":3mj8cyea said:what are we as woodworkers really interested in, the shavings or the wood that is left behind?
I'll be interested to read your findings.how well the tool performs its function particularly in comparison to my Clifton
G S Haydon":23eppjse said:In the spirit of Charles larking about at the end of the day I got this from my 99p wooden jack. Not to corneel's standard but not bad. Timber is beech. Thinking of offering a bespoke net curtain service
Rhossydd":7gqmk9xs said:Absolutely, but surely the two are inextricably linked ?matt_southward":7gqmk9xs said:what are we as woodworkers really interested in, the shavings or the wood that is left behind?
Thin smooth shavings = fine finish
Brings to mind the old farmers saying - you don't fatten pigs by weighing them.Corneel":gn5kfo7a said:G S Haydon":gn5kfo7a said:In the spirit of Charles larking about at the end of the day I got this from my 99p wooden jack. Not to corneel's standard but not bad. Timber is beech. Thinking of offering a bespoke net curtain service
Nice! But did you measure it? :lol:
Personally I want thick heavy shavings and a smooth finish. It's quicker that way and a better test of a plane.matt_southward":3lqy8nvl said:Rhossydd":3lqy8nvl said:Absolutely, but surely the two are inextricably linked ?matt_southward":3lqy8nvl said:what are we as woodworkers really interested in, the shavings or the wood that is left behind?
True enough. I guess it comes down to the degree of fineness that we need for any given task - which obviously varies. I've still a way to go to get shavings as fine as Graham and Corneel, but can still manage a glass-smooth finish. Though not always!
G S Haydon":2jz9751w said:In the spirit of Charles larking about at the end of the day I got this from my 99p wooden jack. Not to corneel's standard but not bad. Timber is beech. Thinking of offering a bespoke net curtain service
