Plane handle repair jig
okeydokey
21 Nov 2014
West Sussex England
A few years ago I went through a phase of buying derelict planes such as Record Stanley and suchlike, most had broken handles (totes) and after fixing a few made a repair jig.
Didn't take too long ,a bit of trial and error with angles and there it was, afterwards tucked it away in a drawer and today I was asked to repair or make a new handle for someone's Stanley No 4.
Out of the drawer a test positional fix, then epoxy and done. Just thought I would show the jig in case it helps someone else with a broken handle or two - yes it could be prettier but does the job
.Not too difficult if you just glue them up, stick them back on the plane, tighten slotted bolt. plus 2" clamps to keep the parts aligned.
If bolt won't tighten it may need a washer. An odd size but luckily easy to find - the ring collar thing on a bike inner tube Presta valve is a perfect fit
I like the simplicity and logic.
What do you do when glue gets on the draw bolt and its stuck in the tote?
Phil
You oil the bolt first. Glue won't stick though it may be a tight fit, with or without glue.
