I need some help setting up a new No5 plane. Let me get 2 things straight first. 1, I normally use power tools for most jobs but recently I have developed a need to do more work by hand (hence the new plane). 2, I am a real cheapskate so any comments like "what do you expect for that money" will find me nodding and agreeing.
I bought an Axminster Jack plane (for the princely sum of £22) basically to see if I could learn to use it. I removed the blade and adjusted the frog as best as I could. I then tried to get the blade back. Problem number 1. The cap iron is not square. Now this may be a stupid question, but, does that matter? I can position it square with the blade edge but the sides run out.
OK. I position the cap iron about 1mm from the edge and insert it into the body. I put the lever cap back on and sight down the sole to adjust the blade. Problem number 2. I cannot retract the blade. The adjusting screw bottoms out before the blade disappears into the sole. From my dim and distant past (school days) I remember adjusting a blade so the it just reappears from the sole. I cannot do this.
My questions are I guess,
Do I have a faulty plane, in which case I should send it back?
Should I grind the blade down thereby shortening it so that it will retract? I don't have a grinder so this may be a little difficult.
Should I buy a new cap iron and blade?
Should I not be so tight and buy a better plane, thereby risking an already shaky bank balance and cries of "How Much"?
Any help would be greatly appreciated.
Bob
Bob
