New housing builds are being wired up with distribution cables that are about 3x the cross sectional area of the legacy stuff according to a recent chat with an engineer from my DNO. I wonder if 3x will be enough ?
But as you know that is just a small part of the issue, I was informed that they will not only require larger csa cables but will also have more cables because each run from the sub can only supply so many houses if they are connected across all three phases. This now raises further issues because with existing supplies the infrastructure, ie ducts etc will also need to be larger and somewhere I read an article explaining that in many heavily populated areas the local subs would need to be put onto 33Kv rather than the existing 11Kv which then need larger footprints so as deema has saidNew housing builds are being wired up with distribution cables that are about 3x the cross sectional area of the legacy stuff according to a recent chat with an engineer from my DNO. I wonder if 3x will be enough ?
The green agenda of all electric cars and everyone using air source was dreamt up by someone smoking waky baky without a clue of the implications.
Both the saw and lathe will need a step-up, or two-stage, VFD as they both require 400V 3ph as they are.Still making no sense to me chaps.
Back to my original question - can I buy a thing to make these 2 motors work from my barns 240v supply or do they need new 240v motors?
So after watching the video posted by Housey210 I think VFD is possibly the way forward. I'm not interested in getting a 3ph suply put in, I just want to run two machines I currently own, any future purchases will be 240v single phase, simple as that.
I'm not interested in future proofing incase I get an electric car, and I live in a listed house which is in a conservation area within a national park, who have said we are not permitted to instal ground source, air sourse, solar or wind power - they don't even want us to have outside lighting (but thats another topic altogether).
So keeping it simple is where I'm at.
If I were to buy VFD's for these machines, I assume due to the different hp ratings on the two motors I'd need two VFD's. So that being said, can someone point me in the right direction for which ones to look at as I expect they'd be different?
Secondly, would this then require the motors to be adjusted or altered to make them work with the VFD'
