Yes the motors will be three phase and operated via contactors but all the control and contactor coil voltages will probably be at 110 volts. Fully agree that you need a real electrician with industrial experience and not a domestic have a go type.
It is really good that at least those types of machine that were once so common across industry in the UK are being restored and used once again even if they
have outlived the industries where they were once so common. I can remember engineering firms where there would be rows of mills, lathes and other machinery all perfoming various task to manufacture some component and all those skilled machinist who would go home at the end of the day smelling of cutting fluid but that was what manufacturing was all about.
The smell always reminds me of my dad. Even when he got to a position where he had no real need to get hands on the machines he couldn't resist it.It is really good that at least those types of machine that were once so common across industry in the UK are being restored and used once again even if they
Does your DRO have this sticker on the backSo, rolling back a bit to the transformer and 110V single phase, am I correct in understanding that the 110V it is supplying is feeding the controls, probably the light, and the DRO so therefore could be fed a 220V Single phase input, while the table drives and spindle motor are fed 3 Phase 415?
When it's turn comes round I fully intend to check each wire, while it's dead, with a DVM and then number them up so I can build up a circuit diagram of what's there and connected to something before hooking up any power!
I don’t mess with electrics but after seeing your post I had a look on the back of the DRO it would appear it can work on 110 or 220v though a look in the electrical box showed everything bar 220v
So presumably you’re thinking of using an independent 220v feed?
