Callum
Hello everyone. In the spirit of the lock down summer we've started doing the garden up, I've laid my first patio, and I'm now going to have a go at a pergola as well and just wanted some advice please. Bear with me though please, as this is a first for me.
The posts and braces will be 150 x 150, and the rest will be 50 x 150. One concern I have, though I might be over thinking it, is the spans for the cross beams and the top beams are quite long, so I was thinking to use C24 treated timber. Would this be strong enough, bearing in mind it should only have a few climbers growing up it over the years, but you never know if one of the kids might think it's a bloody climbing frame at some point!!
I'll use some post bases to raise the posts from the ground that I've seen Mike and others already advise on here, and they'll be secured to concrete footings. I was thinking about 800 - 900 mm deep. Again, this may be overkill?
To fix the cross beams to the posts, I was just going to use 2 x m12 coach bolts, or should I notch the posts as well for extra support. The corner braces could be changed to 100mm x 100mm so would still fit between the 2 cross beams with out needing cutting. These braces will just be bolted to the cross beams, and screwed to the posts, again with coach bolts and screws. If I do notch the posts, would it be to fully house each cross beam, so that there would be 50mm of post left in the middle, or just cut in 25mm for each beam?
For fixing the top beams, I was just going to screw these to the cross beams from underneath, so not to create a small hole for water to collet. I've seen some that got notched and sit on the cross beams, but I thought that may weaken them slightly and might effect the strength across the span? And the ones that run near the posts, again soiled I notch the posts for these or just pop a coach screw through?
The patio it self is quite close to the boundary fence, with nearly 500mm along the back side and about 600mm along the side, so that's why the top beams only overhang on the one side. And I did wander if it's maybe a bit tall? The height to to the top of the top beams will be 2.4 m, so plenty of headroom under the beams (should be around 2.25m)
I will also be making a raised bed and hopefully a roughly 6 x 8 shed at some point as well, so no doubt I'll have plenty of other questions
