duncanh
Hi George
I like the overall appearance but a couple of things that jump out at me-
In photo 2 there appears to be a slight deviation on the underside of the furthest curve. I'm inclined to think that it's actually there rather than a trick of the camera as it's also visible in photo 3.
In photo 3 the lower edge on the cutout looks like it isn't uniform. Where it's level with the top of the rear cutout it looks as though there's a slight raised area. You can just about see it in photo 2 as well.
In photo 2 there appears to be a blemish in the paint/surface - follow the direction of the rear cutout. It could just be that there was a bit of dust when you took the photo. There also appears to be a mark on the surface in the last photo - just above where the lower cut out starts on the left.
I know these comments may be a little picky (ok, maybe a lot!), but the first 2 come from experience yesterday when I was going some cut-outs of my own. If you don't get the resulting cut face at a consistent angle to the turned surfaces it's really obvious. Also time consuming to get right!
The problem with completely painted surfaces is that there's no grain to distract the eye away from any imperfections.
Hope you don't mind the comments - they are intended to be constructive despite how they may come across.
Duncan
Duncan
