Fellas
I realise theres another recent thread about P/T's and didn't want to hijack that one with my own question.
Purchase of a P/T is imminent, main considerations are:
Under £900
Supplied by 13A socket.
I've had a look at the Scheppach 2600ci (is this the same as the 260 mentioned in the other thread - I couldn't find a 260 when i googled it) The other thread makes mention of some niggly problems with this model when converting to thicknessing mode.
Also looked at the Kity 2636, both models appear similar spec but I've not been able to establish whether either will run off a 13A socket (must confess to not looking too hard)
Is anyone able to offer an opinion on either or indeed suggest an alternative. I've had a look at the Axi models as well and it was at about this time that I realised that I didn't really know what I was supposed to be looking for in one of these machines - hence this post.
as for its envisaged use.....
I have a fairly limitless supply of solid oak flooring off cuts (its all grooved on one side hence the requirement for the P/T) and will shortly be starting to work with hard woods from a timber merchants.
Vinny
Under £900
Vinny
