A
Anonymous
Guest
When I first tried it out, the answer might well have been no.
upon inspection, one of the screws had been left loose and tightening this removed the huge inaccuracies
So, i took few test cuts and found that mitres were not too good. Once I noticed a lack of repeatability, I realised the the issue was that wood was sliding a little against the mitre fence as the blade cut into it - I guess the teeth impacting the wood caused vibration and dragged the wood slightly.
So, after a quick chat with mr Osborne (Philly), I stuck the supplied sand paper strip to the fence and voila! perfection!!
Mitre cuts spot on - no need for the shooting board now and the SCMS is redundant :wink: This is a superb piece of kit and I would rate it higher than the Incra mitre's I have seen (and I like Incra!)
Anyone interested in an SIP sliding compound mitre saw with 300mm cut and laser for alignment, pm me with offers. Extremely good condition and about 2 years old
Here are a couple of cuts with the osborne
now, spot the gap
So impressed with the sandpaper on the fence that did the same for the router table
now, spot the gap
