OK. I didn't realise the pads were easy to come by. I've just had a nightmare trying to get some for my MacAllister.That just means you need a replacement pad - they don't last forever and are a common part for most sanders
I had a feeling someone was going to say that...MacAllister is the problem. If you buy a decent make sander such as Bosch, Makita, Festool etc the replacement pads are readily available
started reading that, thought, 'oh great, another selection pack where I'm stuck with a load of bits I don't need'. Then read the rest of the sentence. That is an excellent option, wish it was more readily available, especially when it come to screws (where you always end up with thousands of 12mm screws that you'll barely touch).started using KLINGSPOR disks from a seller on eBay - seem decent enough, and you can do a 'mixed' box, so buy 20/50/100 disks, and specify how many of each grit you want.
Tomas at Casual DIY on YouTube has some ideas with sander plates etc
