One for the motor experts
Skeety
4 Feb 2014
Berkshire
Hi all,
I have just rebuilt a faulty Triton TPT 125 Planer. It's symptoms were sparking from the armature at the commutator end, this was present when not under load. I replaced the brushes to no avail so then did a complete strip down.
From what information I can find many have failed with the exact same symptoms, many under warranty, many not.
On the replacement armature the bearings didn't have to be driven on, they were a light interference fit. I replaced the originals as they had play in them.
The armature that was removed had damage to the commutator, at least 3 segments shorted and damage to the dialectric from heat but was cracked. At this point i didn't investigate further.
Now, the replacement armature sourced from Triton seems to have to me a significant difference in that the fan that is pressed onto the armature shaft seems to have balancing marks on it, the original had no marks whatsoever!
Just interested to see what you think? This is purely out of interest but wondering if the original unbalanced fan could have caused the bearings to wear and then cause damage to the armature...
Pics below:
Perhaps they have tried to address a known issue with the motor, if they have had a lot of warranty returns then they may have done improvements to the motor in that they now realise a balanced assembly runs more smoothly or it could just be the motor is now sourced from a different company. The fact it is metal is unusual as most motor fans are now plastic and therefore lighter.
I'm not sure why they would use a metal fan over a plastic one. I don't imagine the tool drags significantly dirty air through the motor to need the durability of metal. The added mass means that simple pressed metal would need balancing for smooth running.
To be fair, balancing the metal fan ought to be done after assembly as the whole thing is pressed together. Perhaps those balancing cuts are balancing the armature as well as the fan ?
More normally, an armature is balanced by making V shaped cuts into the armature laminations to remove metal. If it is well balanced, the cuts are made at both ends of the armature to balance each end somewhat independently. Cheaper manufacture doesn't bother.
I had an issue with a Samsung washing machine where several of the commutator segments popped and stood proud, causing very rapid wear of the brushes. Apparently due to them switching to a more eco friendly glue in the construction, which turned out not to last very long! Got a free replacement after some to and fro. Reminded me of when BMW introduced water based paint. If a bird left you a present you had to wipe it off almost immediately or it would eat right through to the metal. Cost them a fortune in warranty claims before they got it sorted out.
Thanks all :)
Pretty much what I thought. My planer is now working with the new armature and brushes. I bought it faulty so have fully stripped it, cleaned, lubricated as part of the repair.
A Triton TPT 125 almost like new, including the purchase of the planer and all part for £156 :)
So glad i have found this thread...
I have had to strip mine down, but i am not electrically or over mechanically minded and have had to stop once i got the motor out of the machine. I took off the three screws to separate to plastic motor housing, found a very dirty inside.. then removed i think another three screws but could not remove the plastic housing from the metal motor surround...
Can anyone give me some steps on what i should do to remove the motor to get to the armature to replace, i also have the sparking issue and when under load it really struggles... It never used to...
From memory you just need to tap on the drive pulley with a dead blow hammer, or a normal hammer to free it and it should then come out. It's a while since i did mine.
Make sure you have both brushes removed too. I can see one but not the other. They look fairly worn so you may just get away with changing the brushes.
Whilst it's apart it will be worth you changing the bearings. They are like 10 or less. Also remember that if you are changing the armature you also need to change the brushes.
Can you take a pic from the end of the motor where the drive pulley is?
I did. Thanks. There is a circlip and spring washer behind the pulley. Once removed, and once the two halves of the motor have been separated, then yes, tap the drive pulley with a hammer (on a bit of wood) and drive the shaft through and out. The same at the other end to remove the grill. Note that the pulley is attached to the shaft with a reverse thread. I changed the bearings at the same time. This is a no brainer once you've got this far and is less than £10. Indeed I found that one was in poor condition. Oh, and as well as changing the armature I changed the field as well, under recommendation.
I damaged my pulley with a bearing puller before realising it was screwed on. So stupid as all I had to do was look at the new one. So that was another £10 with shipping.
