Jacob
What goes around comes around.
Dodging again Dave! I think the serious answer is that you haven't tried it. :lol: :lol:David C":2gha665f said:It is pointless giving serious answers to people who make puerile comments.
David
David
CStanford":3n7blpzy said:Maybe it would be informative to start a poll to ascertain exactly how many people on the board are forming four, separate bevels on their plane irons, or plan to do so in the very near future.
Jacob":20pbsvml said:Camber is essential for most plane blades but the jiggers go on and on about flatness and straight edges. How does Dave get a camber with his 5 bevel system (precise, repeatable, etc etc)?
Interesting. What he does basically is press hard to camber as though the jig isn't there. It'd be a lot easier without the jig.iNewbie":3r73ie5r said:...
I'll indulge. :wink: Your bestest pal Chris Swartz has a piece on cambering: Here
Jacob":2ways4re said:Putting a camber on a blade with a straight bevel as he is doing, is not easy. The sensible way is to shape the blade first, square on - effectively a 90º bevel, and then sharpen that.
iNewbie":ii66mop2 said:Jacob":ii66mop2 said:Camber is essential for most plane blades but the jiggers go on and on about flatness and straight edges. How does Dave get a camber with his 5 bevel system (precise, repeatable, etc etc)?
Where exactly (apart from in your own exaggerating mind) do these jiggers go on-and-on about flatness and straight edges. You yourself go on-and-on ad nauseum about Freehand, though - guess you have something in common, there. :mrgreen:
CStanford":17lhpmmm said:iNewbie":17lhpmmm said:Jacob":17lhpmmm said:Camber is essential for most plane blades but the jiggers go on and on about flatness and straight edges. How does Dave get a camber with his 5 bevel system (precise, repeatable, etc etc)?
A camber is a curve through the thickness of a thing. It would be thicker in the middle than at the edges. It's possible Schwarz is doing this but for the most part he (and we) are simply shaping the end of the blade to a curve. It's curved in elevation, i.e. if you look at the cutter from the back, then end is shaped in a curve. This is not camber. To view camber, one would have to look at the bevel straight-on, at eye level, and see the thickness taper from the middle to both edges. This can be achieved on thick plane irons, like those found on scrub planes. It's very difficult to introduce real camber in a thin plane iron, or at least to any degree that matters.
A cambered and curved blade is curved in two planes.
Just seems to mean curved, arched etc in most uses. Usually applies to shallow curves - a bit like "fall" as applied to shallow inclines.CStanford":1x50gorv said:iNewbie":1x50gorv said:Jacob":1x50gorv said:Camber is essential for most plane blades but the jiggers go on and on about flatness and straight edges. How does Dave get a camber with his 5 bevel system (precise, repeatable, etc etc)?
It's easier to control the shape if you grind it, rather trying to force it against a jig the way Schwarzey is having to do. Or easier to do it his way if you take it out of the jig first.David C":sp4imadv said:A most excellent post from Chris.
It's a pity that Jacob seems incapable of understanding it. There is absolutely no need to grind a curved edge for such a small curve. ......
Sgian Dubh":dzxllmx3 said:perhaps this pointless (or is it merely point scoring?) discussion needs putting to bed
Ahhh but this thread is about bevels, sooooooo how many bevels on your bradawl? :mrgreen:Woodmonkey":2jd4rvcr said:I've got a great jig for sharpening my bradawl, takes all the guesswork out
Sgian Dubh":xr005g1f said:Has anyone yet worked out how to sharpen a chisel or plane iron?
Slainte.
Does it come in different colours? :mrgreen:Cheshirechappie":1vxi323v said:Sgian Dubh":1vxi323v said:Has anyone yet worked out how to sharpen a chisel or plane iron?
Slainte.
You'll need one of these, Richard.
http://img.frbiz.com/pic/z2792c9d-0x0-0 ... m_6025.jpg
It can be programmed for single or multiple bevels, rounded bevels, back bevels, front bevels, skew bevels, cambered bevels, no bevels at all and bradawls; and as you can see from the photograph, it even has flashing coloured lights on a stalk. What more could you want?
Cheshirechappie":1f2p6bhw said:it even has flashing coloured lights on a stalk.
I'm trying to decide if it's overly complicated for my needs, or if it's not involved enough. Whilst I'm weighing up the pros and cons I guess I'll just have to rub along (pun intended) with my loosey goosey slip-shod methods of a grindstone, a bench stone or two, and the palm of my hand to act as a strop with a bit of blade flipping.Cheshirechappie":1q9sydq7 said:Sgian Dubh":1q9sydq7 said:Has anyone yet worked out how to sharpen a chisel or plane iron?
Slainte.
