Corneel
When I look at the Raggenbass I don't see anything like the torturing back flattening procedure that some modern authors wants us to do. He hones the bevel and swipes the bevel around on the stone a little bit. That's it.
GLFaria: There is a big difference. Using a handplane on a piece of wood isn't industrial high precision machining. Everything you need to know about using a handplane was allready known back when handplanes were a commercial important factor. Some of that knowledge is lost though, because it wasn't carefully documented.
And sharpening a plane blade is not half as complex as a drill bit. It's just one edge you know. A jig won't give you more relevant precision then doing it freehand.
